Accessing Grid Layout Web Templates
You can access grid layout web templates.
To access grid layout web templates
  1. In Siebel Tools, click the View menu, Windows, and then the Web Templates menu item.
  2. In the Web Template Explorer, expand the Siebel Web Templates tree, and then click CCAppletFormGridLayout.
    Siebel Tools displays the code for the CCAppletFormGridLayout file in the Web Template File window. You can use this template for a form applet.
  3. To view the template, click CCAppletPopupFormGridLayout in the Siebel Web Templates tree.
    You can use this template for a popup form applet.
