Guidelines for Using Code in an MLOV Configuration
If you use code in an MLOV configuration, then use the following guidelines:
Do not hard-code the conditions for a dynamic drilldown or toggle applet. Instead, use the LookupValue function. A drilldown or toggle applet references a business component field that includes a value from a list of values. These values are dynamic. You must not hard-code them. For example, a dynamic drilldown might navigate the user in the following ways:
To a Credit Card screen if the account type is Credit Card
To a Savings screen if the account type is Savings
Never use Siebel Visual Basic to hard-code the Display Value. Instead, use the language-independent code. Siebel Visual Basic does not include a function that gets a Display Value that is specific to a particular language. To write Siebel Visual Basic code using only language-independent code, you must create a calculated business component field that contains the language translation for a language-independent code.
Use the LookupName function only in a calculated field or in a search specification. You cannot use it with Siebel scripting. For more information, see Options to Filter Data That Siebel CRM Displays in an Applet.
For the Pre Default Value and Post Default Value properties of a business component field that uses a list of values list, always prepend the LookupValue function with Expr:. The first argument is the LOV Type. The second argument is the language-independent code. The function returns the Display Value for the language. For example:
Expr: "LookupValue (""FS_PROD_ALLOC_RULES"", ""Default"")"
If you define a search specification for a business component, link, applet, or list, then use the LookupValue function. For example:
[Invoice Code] = LookupValue('FS_INVOICE_CODE', 'Auction')
