How Siebel CRM Sorts a Check Box Field
If a sort specification references a check box field, then Siebel CRM sorts the following values:
  • Y
  • N
  • NULL
If a sort specification references a check box field, and if you define the sort in descending order, then Siebel CRM returns the records in the following order:
  • NULL
  • Y
  • N
