How Siebel CRM Uses Screen Views in Each Navigation Level
The following table describes the type of screen view that is defined for each navigation level and the properties for each screen view. For more information, see About the Siebel Client Navigation Model and Process of Creating a Screen.
Navigation Level | Siebel Client Placement | Object That Is Defined |
1 |
Screen tabs |
Page Tabs, which are child objects of an application. For more information, see Creating a Screen Menu Item. |
2 |
Links in the link bar directly after screen tabs. These links refer to groups of views. |
Screen view with the following properties:
Links in the link bar directly after screen tabs These links refer to a single view. |
Links in the view list in an applet header |
3 |
View tabs These tabs refer to groups of detail views. |
View tabs These tabs refer to a single detail view. |
4 |
Links in the link bar after view tabs, or in an alternate location depending on the web template. |
