Parts of a Search Specification
The following table describes some of the parts of a search specification.
Element | Description |
Comparison Operator |
Compares the value in a field to a constant, or the value in one field to the value in another field. Siebel CRM allows the following operators:
The following is an example search specification that uses the greater than comparison operator:
String Constant |
You use double quotation marks to enclose
the string constant. A string value is case sensitive. Uppercase and
lowercase letters in a string constant must match exactly the string
that the Siebel CRM record contains. The following is an example search specification
that uses the
Logical Operator |
The logical operators AND, OR, and NOT negate
or combine elements in a search specification. Siebel CRM ignores
case in these operators. For example,
Field Name |
You use square brackets to enclose a field name in a search specification. The following is an example search specification that references the Conflict Id field:
LIKE Operator |
The LIKE operator creates a text string search specification where the specification compares the value of a field to a constant, or compares the value of a field to the value of another field. A match on only the first several characters in the string is required. The LIKE operator uses the following wildcard characters:
The following is an example search specification that uses the LIKE operator:
In this example, the Last Name values of Smith, Smythe, Smallman, and so on, causes the search specification to evaluate to TRUE. |
Length |
The search specification must not exceed 255 characters. |
