Using Templates to Configure HTML and JavaScript Toolbars
You can define an HTML or JavaScript toolbar.
To use templates to configure HTML and JavaScript toolbars
  1. Add the following code to the Siebel web template:
    <div od-type="toolbar" name="xxx">   // where xxx is the name of toolbar in the
    repository.
      // any HTML stuff here...
        <div od-type="toolbaritem">
    <!--od section toolbar close-->
    </div>
  2. For combo box items, make sure you target the command to a service.
