Creating a Multi-Value Group (MVG) Applet in Web Tools Using a Wizard
Web Tools provides a wizard to guide you through creating MVG Applets. This allows you to create MVG Applets without having to copy an existing Applet.
To create an MVG Applet using the wizard
  1. Open an editable Workspace.
  2. Click the Magic Wand icon to open the wizard library.
  3. Click the “A” icon with the caption Applet.
  4. Click Start.
  5. Select MVG Applet radio button.
  6. Click Next.
  7. Enter the appropriate data in the Fields.
    Field Description
    Name This is the name for your new Applet.
    Project
    The Project to associate to your new Applet.
    Note: This has been defaulted to 00Phoenix for your convenience. You may choose any Project you wish or leave the default value if you do not use specific Projects.
    Business Component The Business Component from which you will choose Fields and whose data the Applet will handle.
    Upgrade Behavior Choose how Siebel CRM upgrades the applet during an upgrade.
    Display Name Optional. This is how you wish the Applet name to appear when displayed in the user interface. By default, this value will be the name of the Business Component chosen.
  8. Click Next.
  9. Choose the Business Component Fields you would like to display as List Columns in the Applet and move them to the right of the wizard’s Fields Applet.
  10. Click Next.
  11. Choose the Controls that you wish to have on the MVG Applet such as PositionOnRow for example. Move them to the right of the wizard’s Controls Applet.
  12. Click Next.
  13. Choose the Web Template that you would like to use for each Applet Mode.
    Note: By default, the most appropriate Web Templates will be displayed when you open the MVG Applet for each Applet Mode. But you can show all the Web Templates in the Repository by checking the Show All Templates checkbox. This setting can be done independently for each Applet Mode.
  14. Click Next.
  15. Review your choices in the Summary Applet. Click Finish if you are satisfied with the choices or Previous if you wish to change something.
  16. A dialog displays asking if you would like to navigate to the Applet you just created. Click OK to navigate to the newly created Applet. Click Cancel to return to the view you were on before you started the wizard.
