Applying for Products for an Account
Applying for a product for an account involves initiating an application capture process for the product and then submitting the completed application for the product from the Recommendations view. Product recommendations are regarded as a suitable fit for an account.
To apply for a product for an account
  1. Tap Side Menu and then tap Accounts to display the following:
    • The Accounts list and details for the selected account in the main pane.
    • A list in the side pane in which you can select the related items for accounts.
  2. Tap an account in the Accounts list.
    You must select an account where a needs analysis has been completed, otherwise there will be no recommendation information for the account.
  3. Tap Recommendations in the list in the side pane.
    All product recommendations associated with the account appear in the Recommendations list in the main pane.
    The product recommendations shown come from the needs analysis that you started in Performing Needs Analysis for Accounts.
  4. If required, tap Detail to start a Viewer to present additional information about the product and obtain feedback from customers about the presented content.
    The Viewer that you start is similar to the PCD Viewer that is used to deliver personalized content to customers in the Siebel Pharma application. For information about how to use the Viewer, see the following topics:
  5. In the Products applet, select a product and then tap Apply.
    Doing this initiates the application capture process from Intelligent Advisor for the product. The composition and structure of the application capture process varies according to the Intelligent Advisor Policy Model set up for your implementation of the application capture process for the selected product.
    Note: For information about integrating Intelligent Advisor for Siebel business applications, which includes creating and deploying policy model definitions in Intelligent Advisor, see Siebel Self Service Administration Guide. For information about the Intelligent Advisor-specific workflows for Siebel Financial Services, see Intelligent Advisor Workflows for Siebel Financial Services. The sample policy model that is shipped with Intelligent Advisor illustrates the capabilities of the integration between Intelligent Advisor and Siebel Mobile.
    The following options are typically available to navigate the Application Capture view:
    • Next and Back. Tap Next to progress through the application capture process or Back to return to the previous step in the application capture process.
    • Save. Tap to save the application details you have captured so far and exit the application capture process.
      An application record is created under the Accounts, Applications view to which you can return at a later date to complete. For information about resuming a previously saved application, see Managing Application Information for an Account.
    • Submit. Tap to submit the completed application for a product.
      An application record is created under the Accounts, Applications view. After you submit an application for a product, the application must be signed to complete the overall application capture process. For more information, see Managing Application Information for an Account.
    • Close. Tap to exit the application capture process without saving the changes.
