CME Order Management
This ERD (see the following figure) illustrates order management. Companies provide products and services to their customers over an extended period of time. Quotes and orders are used to capture the changes to a customer's installed services. The cycle starts when a customer requests the initial installation of a product or service in the form of a quote. The quote is converted to an order and that order is provisioned. At that time, the products and services described in the order are converted into assets associated with the customer's account. Subsequent changes to the configuration, disconnect instructions, or additions to the installed assets are captured in further quotes and orders. Order synchronization failures can also be tracked.
The following table lists the entities in this ERD and their corresponding tables.
| Entity | Table |
Account |
S_ORG_EXT, S_PARTY |
Asset |
S_ASSET |
Asset Attribute |
S_ASSET_XA |
Order |
S_ORDER |
Order Item |
S_ORDER_ITEM |
Order Item Attribute |
S_ORDER_ITEM_XA |
Product or Service |
S_PROD_INT |
Quote |
S_DOC_QUOTE |
Quote Item |
S_QUOTE_ITEM |
Quote Item Attribute |
S_QUOTE_ITEM_XA |
Failed Service Order |
S_SRV_ORD_FAIL |
Service Request |
S_SRV_REQ |
