Product Recommendation and Offer
This ERD (see the following figure) provides a method for managing product recommendations for up-sell or cross-sell. Product Recommendation allows the user to clearly define the messages, the set of possible responses, and the recommendation itself. Similarly, Product Offer allows the user to clearly define the messages, the set of possible responses, the set of actions for the offer responses, the set of parameters for the offer response, and the offer itself
The following table lists the entities in this ERD and their corresponding tables.
| Entity | Table |
Communication |
S_COMMUNICATION |
Product Line |
S_PROD_LN, S_PROD_LN_PROD |
Product Message |
S_PROD_MSG |
Product Message Response |
S_PROD_MSG_RESP |
Product Message Variable |
S_PROD_MSG_VAR |
Product Offer |
S_PROD_INT |
Product Offer Response |
S_PROD_OFR_RESP |
Product Offer Response Action |
S_PROD_OFR_ACTN |
Product Offer Response Action Parameter |
S_PROD_OFR_PARM |
Product or Service |
S_PROD_INT |
Product Recommendation |
S_PROD_RECMNDTN |
