Siebel Mobile Web Client
The Siebel Mobile Web Client is like the Siebel Web Client except that it includes installable software and uses a local database that synchronizes with the Siebel database.
This topic is part of About Siebel Client Types.
The Siebel Mobile Web Client includes the following:
Installed software. Windows-based software containing Siebel applications and related services is installed on each client. The client also requires a Web browser.
Application connection. Applications run on each client. Applications display in a standard Web browser on the end user’s client computer, such as a laptop.
Database connection. A local database and a local Siebel File System are installed on each client. Applications access the local database.
Users periodically synchronize the local database and Siebel File System with a remote Siebel database and Siebel File System. Users synchronize data using components on the Siebel Server. Mobile users synchronize with the remote Siebel database and the Siebel File System without going through the Siebel Application Interface or any other Siebel Server component. The Siebel Remote (alias Remote) and Disconnected Mobile Synchronization (alias MobileSync) component groups must be enabled on the Siebel Server, among other requirements. The local database for Siebel Mobile Web Client uses Oracle Database SE2.
For information about installing the Siebel Mobile Web Client and the local database and about installing and setting up the server environment to support this client, see Siebel Installation Guide. For information about setting up and synchronizing the local database, see Siebel Remote and Replication Manager Administration Guide. See also the Certifications tab on My Oracle Support.
