Requirements for Setting Up Siebel Mobile
This task is a step in Roadmap for Setting Up Siebel Mobile Disconnected Applications.
Before starting to set up Siebel Mobile, you must meet the following requirements:
  1. The installed software for Siebel Mobile is Siebel CRM 24.1 or later .
    For new or existing installations, install the latest Siebel CRM Update. For more information about new installations and migration installations for existing installations, see Siebel Installation Guide.
  2. For a migration installation for an existing installation, run the Siebel Incremental Repository Merge to update your database to the latest Siebel CRM.
    For more information about using Siebel Incremental Repository Merge, see Siebel Database Upgrade Guide.
    For new installations, running Siebel Incremental Repository Merge is not required. Install a new Siebel database for Siebel CRM.
  3. All standard Siebel Server and Siebel Application Interface configurations have been carried out before you run any Siebel Mobile script on the Siebel Server and Siebel Application Interface.
    • New installations. Complete the standard Siebel Server and Siebel Application Interface installation and configuration tasks to create the object managers for the language or languages that you choose to deploy.
    • Migration installations. Run the script to add the object managers for new Siebel Mobile applications not present in any prior installation, for the existing installed and deployed languages. For Siebel Application Object Managers, run the object manager script for each language that you are deploying. After installation, run the Siebel Management Console and configure the Application Interface to add the new applications.
    • Additional languages. After a migration installation, run the object manager script once for each installed language. If you are adding a new language to an existing installation, then run the object manager script for that language, but only after first completing all the standard tasks to install and deploy a new language as detailed in Siebel Installation Guide.
    Note: The Siebel Bookshelf is available on Oracle Technology Network (http://www.oracle.com/technetwork/indexes/documentation/index.html) and Oracle Software Delivery Cloud. It might also be installed locally on your intranet or on a network location.
