Setting Up CalDAV Publishing on an iOS Device
The following procedure shows you how to set up CalDAV publishing on an iOS mobile device. Before setting up CalDAV publishing on your mobile device, make sure that you can access the Siebel application on your device.
To set up CalDAV publishing on an iOS device (such as iPad)
  1. Tap Settings, tap Mail, Contacts, Calender, and then tap Add Account.
  2. Select Other, then select Add CalDAV Account and enter the following information:
    • Server. The Siebel Application Interface host name (for example, caldav.example.com).
    • Username. The user name to access the Siebel application (case sensitive).
    • Password. The password to access the Siebel application (case sensitive).
    • Description. A description to help identify the calendar in your list of calendars (for example, CalDAV Calendar Work).
  3. Tap Next.
    Note: If the following warning message appears, select Details to review the certificate details, and then select Trust if the certificate is correct: Cannot Verify Server Identify - The identity of <Server> cannot be verified by <Description>. Review the certificate details to continue.
  4. Select Continue when the following message appears:
    Cannot Connect Using SSL - Do you want to try setting up the account without SSL?
  5. Select OK when the following message appears:
    Calendar Account - CalDAV account verification failed.
  6. Tap Advanced Settings, and then select Use SSL if required.
    Your decision to Use SSL or not depends on how the Siebel Application Interface is configured to access Siebel CalDAV and CardDAV.
  7. Specify the port number and then append siebel/dav/<language>/<user_name>/ to the Account URL, for example as follows:
    caldav.example.com:16661/siebel/dav/enu/JDOE
    Note: You can replace <user_name> with the name of whom ever granted you access to their calendar in Siebel.
  8. Tap CalDAV, and then tap Next to start the account verification.
    If account verification fails, go back and check that you have entered all the correct information.
  9. After account verification is successful, select whether you want to synchronize Calendars, Reminders, or both, and then tap Save.
    Make sure you select Calendars.
  10. Tap Calendar on your mobile device, and then select Calendars.
    The list of available calendars appears. The calendar that you just created shows up in this list.
