Handling Custom Headers Using Filters
SOAP headers provide the option of providing optional or mandatory processing information. To process optional custom headers that are provided by external applications, a special business service known as a filter might be defined. Filters can process both request and response headers. A special attribute, mustUnderstand, is used to indicate whether or not the custom header is to be processed:
If mustUnderstand equals 1, then the custom header is interpreted as being mandatory and the custom header is processed by the filter defined for this purpose.
If mustUnderstand equals 1 and a filter is not specified, then the custom header is not read and a SOAP:MustUnderstand fault is generated.
If mustUnderstand equals 0, then no processing of the custom header is attempted.
You must keep SOAP body and header processing isolated. The inbound dispatcher and outbound proxy can process the SOAP body, but cannot set or consume headers. Headers are application-specific. Some customization is needed to set and consume custom headers. To process optional custom headers that are provided by external applications, a special business service, a filter, is defined. You can configure the Web service outbound proxy and the Web service inbound dispatcher to call specific filters for the processing of individual (custom) headers.
