Importing Business Services into Siebel CRM
You can import business services, which you have created in Siebel Tools and exported as XML files, into the Siebel run-time database. This saves time by allowing you to modify business service definitions without having to shut down your production environment, edit the business services in workspace of Siebel Tools or Web Tools, and then deliver the workspace.
To import a business service into Siebel CRM
  1. Navigate to the Administration - Business Service screen, Details view.
  2. From the Menu pull-down, choose Import Service.
  3. The Business Service Import dialog appears.
  4. Browse for a business service XML file, and then click Import.
