Sending and Receiving Messages with EAI MSMQ Transport
The following procedure describes how to set up your system to send a message to an external system using the EAI MSMQ Transport and receive a synchronous message back from the external system by the EAI MSMQ Transport.
To send a literal to MSMQ and receive a response
  1. Access the Windows Computer Management tool by choosing the Start menu, Programs, Administrative Tools, and then Computer Management.
  2. Set up an MSMQ queue to receive messages from the Siebel application, and give the queue an easily identified name, such as fromsiebel.
  3. Set up another queue to send messages to the Siebel application, and give the queue an easily identified name, such as tosiebel.
  4. Set up a workflow in Siebel Tools to send a message out and receive a message back in response using EAI MSMQ Transport. The workflow should contain the following steps, as shown in the following image:
    1. EAI Siebel Adapter (Query)
    2. EAI XML Converter (PropSet to XML)
    3. EAI MSMQ Transport (Send Receive)
    4. XML Converter (XML to PropSet)
    5. Siebel Adapter (Upsert)
    This image is described in the surrounding text.
    Note: For details on the Business Process Designer, see Siebel Business Process Framework: Workflow Guide.
  5. Create the following process properties:
    Name Data Type In/Out
    Test Message
    Hierarchy
    In/Out
    Test XML
    Binary
    In/Out
    Error Code
    String
    In/Out
    Error Message
    String
    In/Out
    Object Id
    String
    In/Out
    Siebel Operation Object Id
    String
    In/Out
  6. Set up the first step of the workflow after Start to use EAI Siebel Adapter with the Query method to query the information from the Siebel Database using the following input and output arguments:
    Input Argument Type Value Property Name Property Data Type
    OutputIntObjectName
    Literal
    Sample Employee
    Not applicable
    Not applicable
    PrimaryRowId
    Process Property
    Not applicable
    Object Id
    String
    Property Name Type Output Argument
    Test Message
    Output Argument
    SiebelMessage
  7. Set up the second step to use the EAI XML Converter business service with the IntObjHierToXMLDoc method to convert the data extracted from the Siebel Database to XML format, using the following input and output arguments:
    Input Argument Type Property Name Property Data Type
    SiebelMessage
    Process Property
    Test Message
    Hierarchy
    Test XML
    Output Argument
    <Value>
  8. Set up the third step of the workflow, after Start, to use the EAI MSMQ Transport business service with the SendReceive method to receive the incoming XML message, using the following input and output arguments:
    <Value>
    Process Property
    Not applicable
    Test XML
    Binary
    MsmqPhysicalQueueName
    Literal
    fromsiebel
    Not applicable
    Not applicable
    MsmqQueueMachineName
    Literal
    SiebelServer1
    Computer name where the Siebel MSMQ Transport is running.
    Not applicable
    Not applicable
    MsmqRespQueueMachineName
    Literal
    SiebelServer2
    Not applicable
    Not applicable
    MsmqRespQueueName
    Literal
    tosiebel
    Not applicable
    Not applicable
    Test XML
    Output Argument
    <Value>
  9. Set up the fourth step to use the EAI XML Converter business service with the XMLDocToIntObjHier method to convert the XML message to a Siebel Message using the following input and output arguments:
    <Value>
    Process Property
    Test XML
    Binary
    Test Message
    Output Argument
    SiebelMessage
  10. Set up the last step to use the EAI Siebel Adapter with the Upsert method to update the Siebel Database, using the following input argument:
    SiebelMessage
    Process Property
    Test Message
    Hierarchy
  11. Save the workflow and run a test using the Workflow Simulator.
    The output property set must have a message in the Value field. Additionally, the EndOfData argument in the property set must be set to True.
    Note: To test this scenario adequately, you must have a partner application that can accept the message and return a response. The correlation ID of the response message must be set to the message ID of the message originally sent by the Siebel application.
