Mapping Between Property Sets and XML
An arbitrary property set hierarchy can be serialized to XML and an XML document can be converted to a property set hierarchy using the XML Converter business service. This service is used by the Business Service Simulator screen to save property set inputs and outputs to a file from eScript.
Each part of a property set object has a corresponding XML construct. The following table shows the mappings between parts of a property set hierarchy and their XML representation.
Property Set Component XML Representation
PropertySet
Element
PropertySet Type
Element name (if Type is not specified, then the element name is set to PropertySet)
PropertySet Value
Element Character Data
Property name
Attribute name
Property value
Attribute value
Child Property Set
Child element
