Example: Using DELETE MATCHES to Delete Data from S_PARTY Extension Tables
If the EIM table’s target table is S_PARTY:
The syntax is as follows:
DELETE MATCHES = S_PARTY, [...criteria...]
DELETE MATCHES = [non-target base tables name of Siebel Extension type],
[...criteria...]
In this example, you want to delete an existing account. This account’s data is as follows:
S_PARTY:  PARTY_TYPE_CD='Organization', PARTY_UID='1-28XIF'
S_ORG_EXT: LOC='San Mateo', NAME='TEST', BU_ID=' 0-R9NH"
If you would like to apply criteria against the S_PARTY table, you can use the following session in the .IFB file:
[Delete Account]
TYPE = DELETE
BATCH = 100
TABLE = EIM_ACCOUNT
DELETE MATCHES = S_PARTY, (PARTY_UID = '1-28XIF')
Or if you would like to apply criteria against the S_ORG_EXT table, you can use the following session in the .IFB file:
[Delete Account]
TYPE = DELETE
BATCH = 100
TABLE = EIM_ACCOUNT
DELETE MATCHES = S_ORG_EXT, (NAME = 'TEST')
Both methods achieve the same result. But in this example, it is easier to use criteria against S_ORG_EXT, since you know which account you want to delete.
Note: When S_PARTY is the target base table, you cannot use the EIM
table name or neglect the target base table name in DELETE MATCHES
expressions.
