Example of Setting a Primary
As one example of setting a primary, you can populate the PR_PROD_LN_ID column in the S_PROD_INT base table by completing the following procedure:
To populate the PR_PROD_LN_ID column in the S_PROD_INT base table
  1. Populate the S_PROD_INT base table using the EIM_PROD_INT interface table.
  2. Populate the S_PROD_LN base table using the EIM_PROD_LN interface table.
  3. Populate S_PROD_LN_PROD using EIM_PROD_INT1 and specifying the primary product lines by setting PROD_PR_PROD_LN to Y.
