CUT Receive Work Order Data Workflow
This workflow receives work order data that is modified in a back-office application because the data must be updated in Siebel Energy.
Workflow Description
This workflow performs the following actions:
- Receive Work Order Update. This step uses the Receive method of the EAI MQSeries Server Transport business service.
- Convert to Internal. This step uses the XML Document to Integration Hierarchy method of the EAI XML Converter business service.
- Update Work Order. This step uses the Insert or Update method of the EAI Siebel Adapter business service.
