Component Parameters for the Replenishment Engine
Component parameters for the engines in Siebel Field Service determine the behavior of each engine. Changing the values of these component parameters changes the default behavior of the engine. To implement changes to component parameters, restart the Field Service server. For more information about changing the values of component parameters, see Siebel System Administration Guide.
The following table describes these component parameters for the Replenishment Engine.
| Component Parameter | Default Value | Description |
SysPref_InvLocTypeForReplenish |
Warehouse |
Specifies the default replenishment level. Orders to replenish any level of an inventory location have this value as the destination. |
SysPref_ReplenishOrderPriority |
Medium |
Specifies the default order priority for newly created orders. The values come from the Order Priority LOV, and individual values are LIVs. |
SysPref_OrderItemStatusForOnOrderQty |
Open, New, Pending |
Specifies the valid values for the existing order item status. The values come from the Order Item Status LOV, and individual values are LIVs. |
SysPref_OrderStatusForOnOrderQty |
Specifies the valid values for the existing order status. The values come from the Order Status LOV, and individual values are LIVs. |
SysPref_OrderTypeForOnOrderQty |
Internal Order, Purchase Order |
Specifies the valid values for the existing order type. The values come from the Order Type LOV, and individual values are LIVs. |
To avoid creating duplicate orders, the last 3 parameters in the previous table specify the order item statuses, order statuses, and order types to find when searching for an existing order.
