Line Items BC Name: TNT SHM Order Entry
Use this user property to get the appropriate business component instance in VBC code.
| Property | Description/Value |
Value |
TNT SHM Order Item |
Parent Object Type |
TNT Custom Menu/Package VBC business component |
Usage |
Creating custom menus and packages is handled through C++ code, and it requires the appropriate business component to be retrieved. This user property is created with the business object. If the active business object is TNT SHM Order Entry, then the TNT SHM Order Entry Item business component instance is created in C++ code to create custom menus and packages. |
