Named Method 7
Use this user property to refresh the business component when the SetParentSplitFlag method is called.
| Property | Description/Value |
Value |
"SetParentSplitFlag", "INVOKE", "TNT SHM Invoice Order Item", "RefreshBusComp" |
Parent Object Type |
TNT SHM Invoice Order Item business component |
Usage |
Refreshes the business component when the TNT Split Qty Flag field is updated for a child menu item, so as to set the appropriate value of Split Menu Flag for the parent menu. This user property works with the On Field Update Invoke user property. |
