Pivot 0 Group by Group Field
If the value of this user property is Y, then the field specified by the Pivot 0 Group Field is used for grouping.
| Pivot 0 Group by Group Field | Description |
Value |
Y |
Parent Object Type |
TNT SHM SR Total Avail Room Specific Dync, TNT SHM SR Type Dync - Group By Type |
Usage |
If the value of this user property is Y, then the field specified by the Pivot 0 Group Field is used for grouping, rather than the Pivot 0 Type 0 values. |
