Shift RoomBlocks
This user property is used to send instructions to the code as to whether or not to shift room blocks during the in-line modification of an arrival date. The default value is Y.
| Shift RoomBlocks | Description |
Value |
Y or N |
Parent Object Type |
Opportunity, TNT SHM Affiliate Opportunity, TNT SHM Sub Opportunity, and Quote business components |
Usage |
This user property is used to send instructions to the code as to whether or not to shift room blocks during the in-line modification of an arrival date. This user property is used in C++ code. The default value is Y. |
