Activating Workflows for Safety System Integration
This task describes how to activate the workflows that are required for safety system integration. You can modify the workflows to suit your own business model, using Siebel Business Process Designer.
This task is a step in Process of Setting Up Safety System Integration for Siebel Medical.
To activate workflows for safety system integration
  1. Make sure each of these Workflow Processes is active. For more information, see Siebel Business Process Framework: Workflow Guide
    • LS Medical Update Product Issue Inbound
    • LS Medical Product Issue Create Inbox Item Inbound
    • LS Medical Product Issue Validation Workflow
    • LS Medical Product Issue Send To Safety
    • LS Medical Product Issue Close
