Associating Help With Messaging Plans
You can create help text for your messaging plan.
To associate help text with a messaging plan
Navigate to the Messaging Plans screen, then the Messaging Plans view.
In the Messaging Plan list, select a record, and drill down on the Name field.
Click the Help File tab.
In the Presentation Items list, add a new help text record for the messaging plan and complete the necessary fields.
Some fields are described in the following table.
Field Description Name
Enter the name of the help file.
Description
Enter a description of the help file.
Sub Type
Use the drop-down list to select a sub type for the help file.
Literature Type
Use the drop-down list to select a literature type for the help file.
To remove a help text record, select the record and then delete the record.
