Communicating about Product Issues Using Correspondence
During the course of an investigation, the quality manager might want to send letters to the contacts associated with the product issue.
The Correspondence feature is used to generate MS Word files (typically letters) where the file is personalized for each contact. That is, information about the contact (name, address, and so on) is incorporated into the letter.
Information about the product issue cannot be incorporated using Correspondence. Use the Proposals feature to incorporate information about the product issue. Predefined correspondence templates are set up by the administrator. End users can edit the generated files in MS Word.
This task is a step in Process of Customer Communication for Adverse Events and Complaints Management.
To create a Microsoft Word correspondence
Navigate to Product Issues screen, then the Product Issue List view.
In the Product Issue List, drill down on a product issue.
Click the Contacts tab.
Select the contacts to whom you want to send correspondence.
From the application-level menu, select File, then Send Letter menu item.
The Correspondence screen appears.
For information about creating correspondence, see Siebel Correspondence, Proposals, and Presentations Guide.
