LS Pharma Call Products Detailed VBC - CE User Properties
The following table describes the user properties that apply to the LS Pharma Call Products Detailed VBC - CE.
| Name | Value | Description |
Template Fields |
Name, Priority, Indication |
Specify the list of fields in the VBC which needs to be updated when a smart call template is applied to the call |
Sort Spec:Pharma Call Products Detailed - CE |
Product Id |
Specify the sort specification to be applied on the Call Product BC. |
VBC Field Map:Pharma Personal Products - CE |
Specify the mapping between the VBC fields and the Personal Allocation BC fields. The mapping syntax is <VBC Field Name>, <Personal Allocation BC Field Name> [|<VBC Field Name>, <Personal Allocation BC Field Name>]. |
VBC Field Map:Pharma Call Products Detailed - CE |
Specify the mapping between the VBC fields and the Call Product BC fields. The mapping syntax is <VBC Field Name>, <Call Product BC Field Name> [|<VBC Field Name>, <Call Product BC Field Name>]. |
Search Spec: Pharma Personal Products - CE |
Specify the search spec to be applied on the Personal Allocation BC. $StartDate$ is the key word which will be replaced at run time with the actual call date. |
Personal Allocation BC |
Specify the name of the BC that holds information about the products allocated to the sales rep for detailing. |
Call Product BC |
Specify the name of the BC that holds information about the products detailed in the call. |
