Pharma GA Call Products Detailed User Properties
The following table describes the user properties that apply to the class CSSBCProductDetailed.
User Property Name User Property Value Description
Max Auto Generated Priority
Number
A numeric value.
Example: 3
Tells the business component the maximum number to go up to when auto-generating priorities for the products detailed.
Template Fields
Field1,field2,…
No start or end comma or spaces between values.
Example: Name,Priority,Product Issue
Tells the business component what fields to copy from the Smart Call template if a Smart Call is chosen.
