Setting Up Codes for Product Analysis
The administrator defines the codes that are used to categorize product analysis.
This task is a step in Process of Product Analysis Following a Product Issue.
To set up codes for Product Analysis
See Setting Up Codes.
Note: Typically, you create codes of type Product Analysis for
use with Product Analysis records. However, all types of codes can
be associated with Product Analysis records.
