Defining Point Subtypes
The following procedure describes how to define point subtypes.
To define point subtypes
Navigate to the Loyalty Program Administration screen.
In the Programs list, select the program that uses the point subtypes you want to define, and click its Program Id hyperlink.
Click the Point Sub Types view tab, then add a new record to the Point Sub Types list for each point subtype. Complete the necessary fields described in the following table.
Field Description Name
Enter a name for the point subtype.
Default
Select the checkbox for one subtype in the list, to indicate that it is the default subtype that is given if no subtype is specified.
