Saving Criteria Library Sets
Use the following procedure to save a criteria library set.
To save a criteria library set using existing criteria
- Navigate to the Loyalty Promotions Administration screen, then the Promotions view.
- Select a promotion.
- Select the Rules tab.
- Click on an existing rule.
- Select the Criteria tab.
- Control click one or more criteria.
- Click Save as Library.
- Complete the necessary fields described in the following table. - Field - Description - Name - Name the Criteria Library set. Note: The name must be unique.- Library Category - Select the Library Category type. - Description - Describe the Criteria Library set.
- Click Create Library.
