Setting Options, Headers, and Footers for Campaign Load Formats
The following procedure describes how to set options, headers, and footers for campaign load formats. In the header, you can add an integration object name but you must not add a system data expression.
To set options, headers, and footers for campaign load formats
  1. Click the Options tab and select the options in the following table.
    Attribute Option
    Purpose
    Campaign Load
    (choose format)
    Delimited File
    End of Field Delimiter
    Comma
    Text Qualifier
    Max # Records
    1000
  2. Click the Headers and Footers tab.
  3. Enter the integration object name to load, using the following format (example also shown):
    Format Example
    # integration object name
    # Marketing Contact
    Note: You must not add additional text or a system data expression to the header. Additionally, do not press enter at the end of the second line. For EAI formatting, there must not be an end-of-line character at the end of the header.
  4. Verify your campaign load format by previewing some sample contents of the list format.
    For instructions about how to preview a list format, see Oracle Marketing Segmentation Guide.
  5. When you obtain the expected results, click the save icon to save your work.
