Verifying the Click Through Daemon Installation
The following procedure describes how to verify the Click Through Daemon installation.
To verify the Click Through Daemon installation
  1. Verify that the Click Through Daemon MS Windows service or UNIX process runs and stays running without an error message.
  2. Open the ctd_InstallLog.log file in the ctd installation directory and read the Summary at the start of the file.
    Make sure it says that the installation was successful with no warnings or errors. If there are warnings or errors, then you must identify the cause and fix the error.
  3. Verify that a ctd.log file exists in the directory ctd_installation_directory\logs.
  4. Verify that the following text is in the ctd.log file:
    INFO OnPremiseAppListener CTD is licensed.
  5. Make sure there are no ERROR or WARN level messages in the ctd.log file.
  6. Confirm that the Click Through Daemon Web container is running.
    Note: To do this, you need the port number that you obtained in Configuring the Click Through Daemon HTTP Server Port.
  7. Verify that you can open the following Web page without an error using Internet Explorer
    http://Click_Through_Daemon_server_hostname:Click_Through_Daemon_http_port/ctd/
    soaprpc
