InsertOrder Method
Insert an order that is defined in the input. If the order already exists, then the method updates the existing order.
Syntax
Product Data Service.InvokeMethod(“InsertOrder", Input Arguments,Output Arguments);
Arguments
Argument | Type | Description |
Input Arguments |
In |
Hierarchy :SiebelMessage(Integration object PDS Order) |
Output Arguments |
Out |
Hierarchy :SiebelMessage |
Error Conditions
None.
This method calls the help method described in DeleteQuote Method.
