Process of Exporting Records to Oracle ATG Web Commerce
Exporting records to ATG Web Commerce requires the following:
Web content export job details. You must create one or more Web content export job details by selecting and exporting records in the Administration - Product, Administration - Pricing or Administration - Catalog screen.
Web content export job header. You must submit the Web content export job header that has these Web content export job details as line items.
The Siebel application automatically creates and maintains Export Contents - Header records in the Administration - Order Management screen. When you create Web content export job details, the Siebel application automatically adds them to an Export Contents - Header record as line items.
The appropriate header record is found based on the search specification for SiebCommIntOpenJob, as described in Creating Separate Web Content Export Jobs for Each User. If none is found, then it creates one base on the value.
Each user can have only one Web content export job header that has not been submitted. If you do not have any unsubmitted Web content export job headers, then the Siebel application automatically creates one when you create a Web content export job detail and adds the Web content export job detail to the job header as a line item. If you do have an unsubmitted Web content export job header, then the Siebel application adds Web content export job details that you create to this header as additional line items.
To export records from the Siebel application to ATG Web Commerce, perform the following tasks:
Creating Web content export job details in one or more of the following ways:
