Process of Setting Up Purchase Order Credit Checking Applications
To set up Purchase Order Credit Checking Applications, you must perform the following tasks:
Configuring Web Services for Purchase Order Credit Checking Applications
Activating the Workflows for Purchase Order Credit Checking Applications
To set up Purchase Order Credit Checking Applications, you can perform the following optional tasks:
Modifying User Properties for Purchase Order Credit Checking Integration
Extending the ASI for Credit Check Interface Request
Note: If you modify any lists of values such as order types or purchase order payment methods, then be sure to review the workflows processes in Credit Check - Quotes and Credit Check - Orders to verify that the application logic to determine whether to call credit check is still correct.
For more information about to how to set up, use, and modify integrations according to ASIs, see Siebel Application Services Interface Reference.
