Process of Setting Up Third-Party Product Availability Applications
To set up the use of third-party product availability-to-promise applications, you must perform the following tasks:
  1. Checking Availability Fulfillment Methods
  2. Setting the ATP Action Parameter in Quote and Order Business Components Properties
  3. Verifying the External ATP Check Business Service User Properties
  4. Configuring Web Services for Availability to Promise
    When setting up the use of third-party product availability-to-promise applications, you can perform the following optional tasks:
  5. Preventing Rollup of Availability Summary Data
  6. Extending the ASI for Availability to Promise
  7. Extending Returned Data for Availability to Promise
  8. Customizing UI Terms for Availability to Promise
    When setting up the use of third-party product availability-to-promise applications, you can perform the following optional task that applies only to Siebel eSales:
  9. Requiring User Registration for Availability to Promise
    For more information about how to set up, use, and modify integrations according ASIs, see Siebel Application Services Interface Reference.
    For information about the employee end user’s experience in using the availability-to-promise features, see Checking Availability to Promise (ATP).
