Setting Up Web Services for Shopping Cart Transfer
To set up the Web services, you must log in to Siebel PRM Manager as a user with system administrator privileges, and then set up outbound Web services and set up inbound Web services.
To set up outbound Web services
  1. Navigate to the Administration - Service Administration screen, then the Outbound Web Service view.
  2. In the Outbound Web Service list, create a query to display the records with "External Shopping Cart Create" in the Name field.
  3. Select Active in the Status field of this record to activate this Web service.
  4. In the Service Ports list, add a new record, and enter the values in the following table in the fields of the new record.
    Field
    Description
    Name
    Enter a name for the port, such as Transfer Cart.
    Port Type
    Select External Shopping Cart Create.
    Transport
    Select HTTP.
    Address
    Specify the address or URL of the target system with which you are communicating.
    If you are communicating with another Siebel instance, enter the following:
    http://webserver/eai_lang/start.swe?SWEExtSource=WebService&SWEExtCmd=Execute&WSSOAP=1
    For the values in angle brackets, use the actual values for your system.
    Binding
    Select SOAP_RPC_ENCODED.
    Comment
    Enter a comment for your own use.
  5. In the Operation Bindings list, add a new record, and enter the values in the following table in the fields of the new record.
    Field
    Description
    Operation Name
    In the picklist, select ExternalShoppingCartCreateSynchronize
    Binding Property
    namespace
    Binding Value
    http://siebel.com/asi/
    Note: Users must activate the workflows before they set up the Inbound Web services, or they cannot select the workflow under the Implementation Name in the Type field. For more information, see Activate Workflows.
To set up inbound Web services
  1. Navigate to the Administration - Web Services screen, then the Inbound Web Service view.
  2. In the Inbound Web Service list, create a query to display the record with "Siebel Shopping Cart Create" in the Name field.
  4. Select the record with the name Siebel Shopping Cart Create.
  5. In the Service Ports list, add a new record, and enter the values in the following table in the fields of the new record.
    Field
    Description
    Name
    Enter a name for the port, such as Receive Cart.
    Type
    Click the select icon. In the dialog box, add a new record and enter the following values in the new record:
    Implementation Type: Workflow Process
    Implementation Name: Select Transfer Cart Inbound Receive Process
    Name: Siebel Shopping Cart Create
    After creating this record, select it as Type.
    Business Service
    Entered automatically when you select the port type.
    Transport
    Select HTTP.
    Address
    Enter:
    Binding
    Comment
  6. In the Operations list, add a new record, and enter the values in the following table in the fields of the new record.
    Field
    Description
    Name
    Enter ExternalShoppingCartCreateSynchronize.
    Business Service
    Entered automatically when you create a new operation.
