About Synchronous and Asynchronous Requests Forwarded by SRBroker to Batch Components
The SRBroker component forwards synchronous and asynchronous requests to batch components like Workflow Process Manager, running on the same server or on a different server. Asynchronous requests can use either of two modes, Asynch mode or DirectDb mode. (Using DirectDb mode is generally recommended.) A target component must be available in order for the request to succeed. Load balancing and appropriate sizing of batch components can help ensure that your server resources are effectively used and that all requests are fulfilled.
The Server Request Processor (SRProc) component, running on each
applicable server, is also used in handling some requests. For requests
made using DirectDb mode, SRProc writes the requests into the S_SRM_REQUEST
table. SRProc running on the same or a different
server also forwards requests to target batch components.
Requests might in some cases cause a target batch component to
reach its maximum number of tasks, as set using MaxTasks
. In such cases, the requests are handled as follows, depending on
the type of request and on the setting of the HonorMaxTasks
parameter on the target batch component:
For synchronous requests or asynchronous requests using Asynch mode, if the target batch component has reached the maximum number of tasks, then the component queues the request in memory for processing when tasks become available. Queuing such tasks minimizes the potential of request failure on the batch component due to the
MaxTasks
value having been reached. However, in some cases, requests might remain in the queue in the process memory, delaying processing.For an asynchronous request made using DirectDb mode (which is generally recommended), the SRProc component on the same or a different server forwards the request from the
S_SRM_REQUEST
table to the target batch component. If the target batch component has reached the maximum number of tasks, and the parameterHonorMaxTasks
isFALSE
(the default setting), then the component queues it in memory for processing when tasks become available. Queuing such tasks minimizes the potential of request failure on the batch component due to theMaxTasks
value having been reached. However, in some cases, requests might remain in the queue in the process memory, delaying processing.For an asynchronous request made using DirectDb mode, the SRProc component on the same or a different server forwards the request from the
S_SRM_REQUEST
isTRUE
, then it is unable to accept the request. However, SRProc on the same or a different server can forward the request from theS_SRM_REQUEST
table to a target batch component for processing when tasks become available. Requests that are queued in the database are subject to less risk due to process failure or hangs than requests that are queued in memory.
MaxTasks
, MaxMTServers
, MinMTServers
, and HonorMaxTasks
are used by the Application Object Manager components for Siebel
Mobile applications, as with other Siebel applications. Load balancing
is supported for Siebel Mobile applications. To support synchronization
for a Siebel Mobile disconnected application that participates in
load balancing, you must set HonorMaxTasks
to TRUE
for the component the application uses for synchronization.Set MaxTasks
and HonorMaxTasks
as appropriate for each batch component, according to your usage
cases, request volumes, and overall topology. Consider that, if batch
components sometimes experience hang issues, then it might be undesirable
to queue requests in component memory.
For help resolving any component failure or hang issues, create a service request (SR) on My Oracle Support. Alternatively, you can phone Global Customer Support directly to create a service request or get a status update on your current SR. Support phone numbers are listed on My Oracle Support.
See also Tuning Workflow Process Manager for Performance.
Related Books
Siebel Deployment Planning Guide
Siebel System Administration Guide
Siebel Business Process Framework: Workflow Guide
Siebel Mobile Guide: Connected
Siebel Mobile Guide: Disconnected
Article 477818.1 (Article ID) on My Oracle Support
