Addressing Performance Issues Related to Grid Layout
This topic is part of Guidelines for User Interface Objects Layer.
The grid layout feature allows developers to create effective and usable form applets for Siebel views. However, performance can be adversely affected by certain applet design choices.
Typically, such performance problems relate to the alignment of user interface controls such as labels and fields, and stem from the total number of cells in the grid-based form applet, including spacer cells. Performance impact will depend on the number of user interface elements, the applet size, and other factors.
You can optimize user interface performance by:
Making stacked sets of labels or fields the same width. Doing so can reduce the number of adjacent spacer cells that you require.
Aligning stacked sets of labels consistently.
Making labels the same height as the adjacent fields.
Eliminating horizontal or vertical spacer cells that you deem unnecessary.
For more information about using the grid layout, see Configuring Siebel Business Applications.
