Analyzing Generated SQL for Performance Issues
Performance troubleshooting is an iterative process. You need to consider performance implications during design and development. Note any changes to potentially troublesome areas, such as MVGs, business component sort and search specifications, joins, extension tables, or indexes. You then test the application to determine bottlenecks, using realistic data volumes and distribution in your test environment. Focus your testing efforts on the slowest, most important, and most highly configured views.
If a performance problem is detected in testing or production, then your next step is to analyze the SQL statements being generated by Siebel CRM. This is one of the most useful diagnostic tools available to you for performance analysis.
This topic contains the following information:
