Running Performance Aggregation Analysis
This topic is part of Analyzing Siebel ARM Files Using the Siebel ARM Analyzer Tool.
Use the following procedure to obtain performance aggregation analysis output. For a description of the performance aggregation analysis and output, see About Performance Aggregation Analysis and Data. For more information about running the Siebel ARM Analyzer Tool, see Analyzing Siebel ARM Files Using the Siebel ARM Analyzer Tool and About the Siebel ARM Analyzer Tool.
To run a performance aggregation analysis
Navigate to the
bin
subdirectory within the Siebel Server root directory.- Run the Siebel ARM Analyzer Tool using the following command:
sarmanalyzer -o output_file_name.xml -a aggregate_argument -f sarm_file_ name.sarm
where:
output_file_name
.xml
is the name and path of the XML output file.aggregate_argument is either AREA or DETAILS, depending on which area you want the Siebel ARM post-process tools to aggregate data from. For more information, see About Performance Aggregation Analysis and Data.
sarm_file_name
.sarm
is the name and path of the binary Siebel ARM file. Use a comma-delimited list to aggregate data from more than one Siebel ARM file. Review the XML output in the file named output_file_name.xml. For more information about analyzing the performance aggregation analysis XML output, see About Performance Aggregation Analysis and Data.
