Tuning System Components
This topic is part of Guidelines for Siebel Web Client Tuning.
Overall end user performance is affected by the processing on the client as well as by everything from the Siebel Application Interface to the Siebel database and back. Explore all applicable areas for opportunities to improve overall performance.
Most performance tuning involving Siebel Server components focuses on the Siebel Application Object Manager. For more information, see Tuning the Siebel Application Object Manager for Performance.
You can use Siebel ARM to monitor transactions through the Siebel infrastructure. Note areas which require substantial time and resources, and investigate them further for tuning opportunities.
For example, a custom configuration might have resulted in an unintentionally complex SQL statement for which the database instance has not been optimized. Small configuration adjustments in Siebel Tools, or database tuning, can improve both client performance and application scalability on Siebel Servers. For more information about Siebel ARM, see Monitoring Siebel Application Performance with Siebel ARM.
