Using the USE INDEX HINTS and USE ESSENTIAL INDEX HINTS Parameters
This topic is part of Troubleshooting Siebel EIM Performance.
Perform testing with the IFB file parameters USE INDEX
HINTS
, trying
both settings (TRUE
and FALSE
The default value for USE INDEX HINTS
is FALSE
. The default value for USE ESSENTIAL INDEX
HINTS
is TRUE
USE INDEX HINTS
within each
one.If these parameters are set to FALSE
, then Siebel
EIM does not generate hints during processing. By setting the value
to FALSE
, you can realize performance gains if the TRUE
setting means that hints are being generated that direct
the database optimizer to use less than optimal indexes. Siebel EIM
processing must be tested with both the TRUE
and FALSE
settings to determine which one provides better performance
for each of the respective Siebel EIM jobs.
USE INDEX HINTS
parameter is applicable
only for Oracle Database. The USE ESSENTIAL INDEX HINTS
parameter is applicable only for Oracle Database and Microsoft SQL
Server.These two parameters work for different queries, so you have to enable both to get all of the index hints on Oracle Database.
Further information is provided as follows:
