Using Test Mode to Test Personalization Rules
See also About Test Mode and Using Test Mode to Test Personalization Rules.
You can test personalization rules in a staging environment before being used in the production environment. This is done in the Test view under Personalization Administration.
To test personalization rules using Test Mode
Navigate to the Administration - Personalization screen > Test view.
Either:
Click Open to use a saved test setup, or
Fill in the following fields, and click Load
Field Description Primary User Login
Required. User who is logged in to the application, such as a call center agent.
Primary User Password
Required.
Secondary User Login
Optional. Someone who interacts with the primary user, such as a customer speaking with the call center agent.
Test Application
Path to the test application.
For the Siebel Web Client use a URL, for example:
http://<machine_name>/callcenterFor the Siebel Mobile Web Client use a command string, for example:
D:\<Siebel_install_dir>\BIN\siebel.exe /l language_code /c "D:\<Siebel_install_dir>\bin\ENU\config_file.cfg" /d data_sourcewhere:
<Siebel_install_dir> is the full path to the client installation directory
language_code is the three-letter code for the language, for example,
ENUfor US English andconfig_file is the application configuration file, for example,
uagentfor Siebel Call Center andsiebelfor Siebel Salesdata_source is the database to which to connect: Local, Sample, or ServerDataSrc
Test View
Optional. If not specified, the screen is blank when the test application launches. You have to navigate to a view.
Select an attribute to edit its value.
The persistent user profile attributes of the:
Primary user are loaded into the Primary User Attributes list with a
Me.prefix.Secondary user are loaded into the Secondary User Attributes list with a
You.prefix.Name and Source fields are read-only for persistent user profile attributes.
Person-related attributes have the value
Personin the Source field.Organization-related attributes have the value
Organization.
Add a new record under Primary User Attributes or Secondary User Attributes to add a new dynamic user profile attribute.
Fill in the Name and Value fields.
The Source field is read-only and has the value Dynamic.
Click Test under the Test tab and take the following action.
If... Then... You are using a connected Web Client (accessed though an appropriate URL).
The Test Mode dialog box appears, which prompts users to open a new browser window (by using a desktop icon or the Start menu, if using Windows).
The Test Mode dialog box provides a URL to paste into the new browser window.
You are using a Mobile Web Client.
A new instance of the application opens.
Go to Step 9.
Copy the URL shown in the Test Mode dialog box, and then click OK.
Open a new browser window, and then paste the URL into it.
A new instance of the specified application launches.
If the test view was not specified, the screen is blank and you have to navigate to a view.
After testing personalization rules, click Save in the Test view to save the test setup.
