Customizing Recommendation Messages for Product Promotions
This task is a step in Process of Creating Product Promotions.
By default, if the application recommends a promotion, then it displays a message in the following form:
Recommend promotion ‘[Prod Prom Name]’: [Promotion Description]
You can customize the form of this message.
To customize the recommendation message for product promotions
Navigate to the Administration - Application screen and in the link bar, click Message Types.
In the All Message Types list, query to find the record with the name Promotion - Bottomup Recommendation.
In the Message Type view, enter the desired message in the Full Text field.
