Specifying Price Adjustments Applied to a Product Class or a Product Line in a Product Promotion
Use the following procedure to specify price adjustments applied to a product class or product line in a product promotion.
To specify price adjustments applied to a product class or product line in a product promotion
  1. Navigate to the Administration - Product screen, then Product Promotions view.
  2. In the Product Promotions list, select the promotion for which you are specifying the pricing.
  3. Click the Pricing view tab.
  4. Click Aggregate on the link bar in the Pricing view.
  5. In the Pricing Aggregate list, add a new record and complete the necessary fields as described in the following table.
    Field Comments
    Type
    Select the type of aggregate adjustment. The options are as follows:
    • Aggregate – Default. This is a default pricing rule. If the line item product does not match any individual product pricing rule or any conditional aggregate pricing rule, then the line item price is adjusted using this default rule.
    • Aggregate – Conditional. The adjustment is applied to product classes or product lines. When this value is selected a user must define the Group Field and Group Value fields.
    Product Line
    If you selected Aggregate - Conditional as the type, then you can select a product line to which the adjustment applies.
    Class
    If you selected Aggregate - Conditional as the type, then you can select a class to which the adjustment applies.
    Adjustment Type and Adjustment Value
    Enter the price adjustment. These fields are used in the same way as in the Pricing Components view, which was described in the previous procedure.
  6. If you selected Aggregate - Conditional as the type, then you can add more records to define adjustments for additional product lines and classes.
