About Default and Custom Siebel Configurator User Interfaces
You must decide whether to use the default Siebel Product Configurator user interface or to design a custom user interface.
The default user interface displays all the configurable items in the customizable product on a single selection page. If you create a custom interface, you can display the configurable items on multiple pages.
The default user interface makes intelligent choices for UI controls based on attribute domain type and upon relationship cardinality. For example:
- If an attribute has an LOV type domain, the default interface displays a combo box for setting the attribute.
- If a relationship has a min and max cardinality of 1, the application displays a combo box without multiple instances. If the max cardinality is greater than 1, the application displays a combo box with multiple instances.
If you create a custom interface, you can select the control used for each configurable item, and you can create several Open UI interfaces and assign them to users based on their responsibilities and their browsers.
The application decides which interface to assign to a user using the decision flow shown in the following figure.
